1meansc's Avatar
Please help identify 993 cam
Hi guys,
Please could you guys help identify the following cam. The numbers on the cam are: 993 246 70. I believe there should be a 105 added into to the number. I believe the full number should be 993 105 246 70.
I checked with the local Porsche agent, but they have no record of the cam shaft number.
The numbers definately look like they are Porsche numbers.
I was told that they were Porsche racing cams.
Any help identifying these cams as well as the recommended timing specs for this cam would be appreciated.
By the way, I know this is only the RH cam, I do have the left cam as well
Thanks in advance.
Markus
Old 04-01-2005, 08:22 AM
Glenn from Denv's Avatar
The 70 at the end of the part number is consistent with what I know to be Porsche's nomenclature for racing parts.
_______________
Glenn from Denver
94 964 3.8 RSR
Old 04-01-2005, 08:46 AM
1meansc's Avatar
Thanks Glenn,
But can anyone help with more info & timing specs.
Old 04-01-2005, 09:48 AM
camgrinder's Avatar
I have seen that number on the nose of the 993 super cup cams. The specs are on my website. 2.0 mm is the setting.
John Dougherty
Dougherty Racing Cams
Old 04-01-2005, 01:36 PM
