Threadlock question..
Which 'Loctite' Threadlock should I be using on my exhaust port studs, valve covers and the like on my Carrera 3.0 Engine. I was under the impression that 'Red' was the one. Just visited the Loctite site and there are loads of different 'Red' types.246,294,222,222MS etc.etc. Does it really matter which I use? I'm sure it does....cheers M
I wouldn't use any on the exhaust port studs. "Red" Loctite is usually 272 here in the states.
-Chris |
Having just had to drill out, re-tap and helicoil three of my exhaust studs I have a sneaky suspicion they don't fall out to often;)
I would actually use anti-seize in the threads, and just check the nuts periodically. Much easier than replacing broken studs.;)
Many thanks...no thread lock on the exhaust studs. Just copper grease. How about using stainless steel bolts instead of studs. Wouldn't that stop them seizing inplace?
M PS Just out of interest '911mot'..are you aware of P. Auto Car boot coming up on 23 April? Seeing as you're a 'local' |
I don't think that stainless and aluminum goes together that well. I not sure but someone may be able to clear that up?
Closer inspection of the page reveals another jumble sale going on as well:D http://forums.pelicanparts.com/uploa...1112658427.jpg |
Knowing those guys reputation and seeing some of their "work" firsthand, I'm embarrassed to be a Californian.:( Ralph |
But are you really a Californian??!?!!!?? :) Just kidding!
Jeff |
| All times are GMT -8. The time now is 04:50 AM. |
