-   -   Rocker arm leak w/RSR 'O' ring? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/214671-rocker-arm-leak-w-rsr-o-ring.html)
GBStu 04-05-2005 09:25 AM
I have just finished the rebuild of my 3.0 SC, after driving it for 50 miles or so I noticed an oil leak from the rocker arm. I tried to tighten the rocker arm bolt but could not get any more torque on it than it already had (difficult to get a whole lot of torque on it when the engine is in the car).
What I don't understand is why it is leaking when I used the RSR seals.
I have ordered new seals from Pelican, but before I reinstall them I would like to know if there's any "special" assembly process or guidelines?
Stu
ChrisBennet 04-05-2005 10:33 AM
Tightening them will keep the from moving but it won't really do much for leaks. Your rocker shaft bore(s) may be so scratched that even the RSR seals can't stop the leaks. If the rocker shaft itself is somehow scratched (not as likely) and the bore is OK, you could replace the shaft.
If the shaft is leaking on the end that is not flush with the end of the hole, you might try plugging it with RTV/Silicone. A friend of mine told me about that trick but I haven't tried it personally.
If the bore and shaft look good, check the RSR seals for rips. I got a few bad ones a while back.
-Chris
jimbauman 04-05-2005 06:25 PM
It's also possible to get the seals on inside out - not sure if that has an effect on the sealing ability however...
JB
TimT 04-05-2005 06:29 PM
really? now that will be a stretch
jimbauman 04-05-2005 06:35 PM
Yup. The seal is flat on one side, and tapered on the other. When you roll the seal into the groove, you need to make sure the flat side is out.
JB
Jeff Alton 04-05-2005 07:28 PM
uhhhhhhhhhhhh what?
jimbauman 04-05-2005 07:38 PM
Huh, eh?
kstylianos 04-05-2005 07:54 PM
Yes, JB is correct. Take a good look at an RSR seal.
addictionMS 04-05-2005 10:10 PM
have one in my hand and I have no idea what you are talking about.
Jim
jimbauman 04-05-2005 11:01 PM
I'm almost thinking there may be two different flavors of RSR seals out there. On one variation, the inside surface and outside surface are both flat. On another variation, the outside surface is flat (the surface that contacts the rocker arm bushing), and on the inside surface, it is shaped to fit the groove, which is narrower at the bottom of the groove than it is at the top.
JB
Jeff Alton 04-05-2005 11:11 PM
Oh I get it now the "eh" part is an atempt at humor. Fine. Tell me how you turn one inside out. Maybe I am missing what you are saying. Do you mean you have the outer most diameter sitting in the grove on the shaft and the inner, substantialy smaller, diameter sealing against the bore in the cam housing?
Jeff
jimbauman 04-06-2005 07:04 AM
You got it.
JB
jimbauman 04-06-2005 08:56 AM
If you try to slide the seal onto the shaft in the correct orientation, it will probably have a tendency to "roll." I found them a little tough to simply slide. By the time you get to the groove, it could roll into position with the flat side down in the groove, and the tapered side out.
There may not be any downside to installing the seal like this, except you have less surface area of the seal contacting the rocker arm bushing. Certainly, anything in there has to be better than nothing.
JB
magic930 04-06-2005 01:15 PM
When installing the rocker shaft it is important that the bore is completely clean and scratch free. I attached a piece of medium grit "wool" sanding pad to a long 1/4" wooden dowel, just fold a piece over the top of the dowel and tape with electrical tape, put that in a power drill and spin it in the bore, they cleaned and polished up nicely. Put the shafts in dry except for spray silicone to make sure the RSR seal slides in without binding up. 1400 miles no leaks so far!
kstylianos 04-06-2005 05:25 PM
Hopefully this makes it clearer.....
In the first picture you can see the OD profile of the seal has a radius.
Second picture shows the ID profile is flat.
Very easy to get them inside out when trying to slide into the rocker shaft recess.
The rocker shafts should not leak, period......w/ or w/o seals. Would not blame this problem on a seal that’s been flipped, though. Think you may have other issues (scored or oblong bores).
http://forums.pelicanparts.com/uploa...1112833527.jpg
http://forums.pelicanparts.com/uploa...1112833548.jpg
jimbauman 04-07-2005 08:46 PM
Excellent pix Charlie. But, I noticed the inside diameter has the flat side. So, this brings up the question - which side is really designed to seal against the rocker arm bushing? There are no instructions with these things! How are they shipped? Flat side in or out?
JB
kstylianos 04-08-2005 12:31 PM
They are shipped and should be installed as shown, "flat side in". They will not hold their inside-out orientation at all, unless forced into a tight recess, like the rocker shaft.
jimbauman 04-08-2005 01:56 PM
Flat side in ..... but if you look at Wayne's rebuild book, figure 6-17, it looks like the flat side is out! Hello, Wayne?
I checked my notes and I installed them flat side in - they just went in the groove easier that way....
JB
hcoles 04-08-2005 05:00 PM
JB,
I hope we can clear up the flat side in/out ....then there's the pointy part of the taper in/out....which way does that go? or is the point symetrical? I need to know....engine getting ready to go back together.
-h
jimbauman 04-08-2005 05:04 PM
By all accounts, the pointy part is the surface that runs against the opening in the cam housing.... JB
kstylianos 04-08-2005 05:18 PM
There is no taper on radiused end. Yes, it’s symmetrical.
By all accounts, the pointy part is the surface that runs against the rocker arm bushing.... JB
I have a hard time believing that is the correct orientation. If they wanted 'flat side out', why wouldn’t they manufacture them in that orientation? Would you flip over any other gasket or o-ring? I don't want to start splitting hairs here, just logically don’t think that's correct.
jimbauman 04-08-2005 05:34 PM
Charlie - I'm agreeing with you - the radiused edge of the seal is exposed when installed on the shaft, and is the part of the seal that makes contact with the cam housing (I said rocker arm bushing earlier - my goof).
I guess what confused me from the get-go was the picture in Waynes book, where it appears that the seal is installed on the shaft with the flat side exposed...
JB
kstylianos 04-08-2005 06:04 PM
Doh, crossed wavelenghts. Sorry bout that. http://www.pelicanparts.com/support/smileys/wat2.gif
snowman 04-08-2005 10:19 PM
What the F???? If you can't seal your rocker shafts with this ring on either way you need help. Serious help. The things should seal WITHOUT any extra help, but if they don't with these rings, they are shot, gone, unusable and need reconditioning by a competent Porsche machinist.
