Looking for Piston Ring Set for '73.5T with CIS
found.
Anyone know where to source a piston ring set by Goetze (OEM) for the 1973.5T with CIS. Our host is out of stock and does not see any in the future. EBS is in the same boat. Drive Wire claims to have Deves in stock but they can be hard to seat. The 2.4L with CIS uses a middle ring that is 1.75mm which is different from the others using a 1.5mm ring. I'm hoping Henry or John will have an answer. |
| All times are GMT -8. The time now is 07:47 AM. |
