Carl Ashcroft's Avatar
Question Oil pressure relief plug torque?
Waynes book shows the torque spec for the oil pressure relief valve plugs at 44 ft-lb. Seems like too much. Can that be right?
Does anyone have this spec from a second cource?
Old 04-22-2005, 08:20 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Bentley Manual confirms that the tightening torque is 60 Nm or 44 ft/lbs.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 04-23-2005, 08:11 PM
All these plugs have to do is not leak and not come loose. I don't use a torque wrench on them. I Just tighten them enough to start to crush the washer lightly and feel like they will stay tight.
-Andy
Old 04-23-2005, 09:02 PM
Ralph and Andy,
Thanks for the info. At about 44 ft-lb, the washer began to squeeze out the sides and the wrench actually became easier to turn. I was afraid I was stripping the threads in the crankcase, so I backed it out. Later I tightened it snugly (enough to crush the washer slightly) with a new washer and left it at that.
-Carl
Carl
'80 911SC 3.0
Old 04-23-2005, 10:05 PM
