-   -   Rering / cylinder - Needs Help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/217847-rering-cylinder-needs-help.html)
SteveBorelli 04-23-2005 08:11 AM
Dear all,
I'm from Italy, so sorry for my poor English.
After I purchased the best two Wayne's books "How to Rebuild Porsche 911 Engines" and "101 Projects", I opened my 2,4 E 165HP Engine to make a rebuild of it.
When I've took off one of the cylinders and measured it, I discovered it is out of Porsche tolerances.
So, I went on a Porsche mech. and asked for alternatives. These is what he suggest :
1 - Buy brand new 2.4 cylinders, change rings, use old pistons
2 - Machine my old biral cylinders (about .4mm), buy a new and right sized pistons set with new rings
Now, I red deep the forum and I have not truly understood if there are other options.
For examples it seems that there could be a way to use "over-sized" rings over the old pistons in the machined cylinders (.4mm bigger); I talked to my mech but he says this is an old technique that does not guarantee any result...
Who can give me a clear idea of what to do ?!? (of course this workarounds are intended to keep the budget as low as possible)
Thank you in advance.
Ciao.
Stefano
Steve@Rennsport 04-23-2005 12:00 PM
Hi Stefano:
There are several ways to repair your motor, but the RIGHT way would be to machine your Biral cylinders and install new, oversize pistons & rings.
That makes a good repair that will last a VERY long time,....:)
Ciao,
Superman 04-25-2005 01:26 PM
Using oversized rings on original pistons with bored cylinders would be, in my opinion, a bad decision.
350HP930 04-25-2005 03:44 PM
Go with the new oversized pistons.
If the old cylinders are out of spec your pistons are pretty shot too.
