What are shortcomings of having crank Re-Nitrided and polished to get the journal bac
What are shortcomings of having crank Re-Nitrided and polished to get the journal back after spinning rod bearing(it is not that bad but they often are not that bad). $900-1000 is cost to fix crank.
What is the difference if I use such a "repaired" crank on a (i) steeet, (ii) race track. And has anyone been using Armond at CCR for crank work. He comes highly recommended.Who else does the nitriding well? Thank You |
The journal will usually have to be welded first, then nitrided. I have seen crankshafts with welded journals used in 911 engines that see 9000+ rpms without any problems.
Armando does excellent work. He can also be very very slow. |
There is nothing wrong with a reconditioned crank as long as it is done right.
do a search for armando/ccr.
what about nitrating con rods? I have seen rsr rods nitrated, what does this do to the metal and why was it done?
| All times are GMT -8. The time now is 03:50 AM. |
