Intake Manifold Gasket
I am in process of putting intake manifold back on block on a 70 911T with Zenith Carbs.
I can't find information about using gasket sealer for the gaskets (intake manifold to head and carburetor to intake manifold). Previous owner used sealer on both ??. Any thoughts ? Based on prior experience I am inclined to install both sets of gaskets dry on cleaned surfaces. Jon |
The sealer that I use for that gasket is a marine type. Is use for outboard marine engines. I dont remember right now the name. Looks like Shellac but not are the same. Is better. The small white can with blue letters says: gasket maker. The color is like dark purple. I found it at Pep Boys.
Green gaskets should be used dry.
| All times are GMT -8. The time now is 10:14 AM. |
