-   -   Which TDC when installing distributor? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/220563-tdc-when-installing-distributor.html)
axl911 05-09-2005 06:35 AM
Hi all,
I've completed the cam timing step in my rebuild. But now I am not sure which Z1 is the correct one to be used for installing the distributor.
I would assume that it would be at the Z1 where both cyl 1 intake and exhaust valves are completed closed. Not the one where you set the "intake valve stroke in overlapping TDC with .1mm valve clearance" right?
thanks,
anthony
ChrisBennet 05-09-2005 06:53 AM
You set the distributor to point to #1 at the TDC that has both valves on #1 with .1mm clearance. That clearance is there because the rocker isn't pushing the valve i.e. the valve is completely closed.
-Chris
axl911 05-09-2005 08:05 AM
I have only set the cam timing on cyl 1 and 4 intake, and have not adjusted the valves yet.
I am trying to figure cyl 1 TDC to begin adjusting the vales and installing the distributor. What is tripping me up is there are 2 Z1 positions out there, one for cyl 1 TDC and the other is for cyl 4 TDC. And I am trying to figure out which is which.
thanks,
anthony
ChrisBennet 05-09-2005 08:23 AM
I *think* I understand what you're saying. The TDC that you want (#1) is the one when both cams have the writing on them end right-side-up.
(The writing on the cams will be up-side-down at TDC for #4.)
Does that help?
-Chris
axl911 05-09-2005 08:36 AM
That is exactly what I am looking for. Thanks a lot Chris!!!
---anthony
