Need Pic of Worn Rod Bearings...
For the BMW book I'm writing - can someone shoot me a pic of some worn rod bearings showing the brass underneath? I can't believe I don't have a picture of this, but I've combed through my 12,000 pics from the Engine Rebuild book and the 101 Book, and I seemed to have missed that.
Either that, or if you have a worn bearing that fits that description, I'd love it if you could mail it to me at Pelican. Many thanks! -Wayne |
If not today, its only a matter of time before I will come across a rod bearing that has worn through to the copper backing.
As soon as I have one I will send you a few pictures. |
Here is one from an intermediate shaft if that helps at all.
http://forums.pelicanparts.com/uploa...1115829689.jpg |
something along these lines?
http://img27.echo.cx/img27/3844/dscn06019ly.jpg I belive it's from a SBC but not sure, happened to see it on another forum (actually the automotive section of a computer site) |
Man those ARE worn! Sheesh!
http://forums.pelicanparts.com/showthread.php?s=&threadid=192606&highlight=BEARIN G
doenst look like brass in there.... |
Does this one qualify? Its from the a 2.4CIS engine I took from my 1973T.
http://forums.pelicanparts.com/uploa...1115918166.jpg |
Here's one of a motor that ran fine albeit tired. Caught it before the crank got damaged.http://forums.pelicanparts.com/uploa...1115944410.jpg
Oops better picture here.http://forums.pelicanparts.com/uploa...1115944526.jpg
Modern BMW bearings might be Aluminum underneath and on top.
Too long oil-change interval together with dino oil leading to clodged oil galleries which in turn lead to spun rod bearings:
http://luminasweden.com/temp/IMG_8044.jpg |
| All times are GMT -8. The time now is 12:06 AM. |
