Air Medal or two
afterburn 549's Avatar
rocker shaft comes out!!!
Was doing a valve adj/RSR seal job the other day and there looking back at me was a rocker shaft working its way out of his home !! I have herd of this b4 -when I installed them I know they were all torqed dwn. Whats the reason for comming out??
I think next time I have things apart I will drill the rocker boxes and place a set screw in every shaft
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 05-16-2005, 07:11 PM
used ones need about 20# torque to stay put. the factory spec is not sufficient.
206 637 4071
Old 05-16-2005, 07:59 PM
I echoed your sentiments... one of my rocker arm adjustment nuts backed out on me completely Thank god it only fell to the bottom valve cover instead of through the oil tube into the crankcase.
Guess I muse have been sleeping when I did my valve job last time to not tighten them enough.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 05-16-2005, 08:51 PM
Air Medal or two
20 lbs??I know you know what your talking about John, just seems like I would break them lil things right off.
Old 05-16-2005, 09:07 PM
if they break, they were already cracked.
206 637 4071
Old 05-16-2005, 09:48 PM
Air Medal or two
Ok ,thanks
Old 05-16-2005, 10:01 PM
