-   -   Leak from Case Stud Under #1... Ideas? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/221614-leak-case-stud-under-1-ideas.html)
Fishcop 05-16-2005 01:12 AM
Hi All
It would appear that the stud under cylinder 1 on the case is the source of a nasty leak. I torqued it up a little while ago but it loosened off... read: pulled :(
If I clean it up and dose it with JB Weld or Sikaflex, will this work? How essential is this fastener given it's next to case through bolts?
I'm p!ssed as I asked for the case to be "gone over completely" which I thought included a timecert (or at least a helicoil) at this stud.
Thanks for any input
Bob Goding 05-16-2005 05:03 AM
John, is this the one to which you refer?
Hope this helps.
http://forums.pelicanparts.com/porsche-911-technical-forum/168052-intermediate-stud-pulled.html
Cheers ,Bob
Fishcop 05-16-2005 05:31 AM
Bob, you're a legend!
JWW... even bigger legend!
Bob Goding 05-16-2005 05:34 AM
Yes, I find that anything from John Walker is worth saving,for future
reference.
Bob
