-   -   Camshaft choice for turbo 2.7 with EFI (http://forums.pelicanparts.com/911-engine-rebuilding-forum/221915-camshaft-choice-turbo-2-7-efi.html)
dweymer 05-17-2005 12:41 PM
Anybody have recomendations for camshafts in my motor? It will be a 2.7 turbo, with EFI. Undecided on pistons, may use the stock CIS, as motor only has 85k on it. Street/track use, weekends etc; not a daily driver.
trak ratt 05-17-2005 05:00 PM
2.7 liter engines aren’t usually used as basis for turbos. Most came with 8.0 or 8.5 compression ratios, which is pretty high without a knock sensor so timing will be crucial. Factory 911 3.0 liter tubos from the same era were 6.5 and 7.0 cr and used stronger cases. Though EFI might support bigger profiles, I believe your piston crowns will limit your cam selection to not much more than the stock CIS grinds. I’m pretty sure this is also what the factory used. Do a search on CIS cam upgrades and you will see what I mean. Usually, the 964 profile is as radical as you can go with stock pistons.
A 2.7 would not be my first choice for a turbo upgrade.
dweymer 05-17-2005 05:26 PM
I agree that 2.7's aren't usually used for tubo apps; but it's what I have. 8.5 comp should be fine with EFI. I was thinking about the 964 grind also.
air-cool-me 05-17-2005 05:35 PM
"Most came with 8.0 or 8.5 compression ratios, which is pretty high"
that is great for boost under 1bar...
strokher racing 05-17-2005 06:38 PM
I would ask camgrinder what he could do on a custom cam basis. His pricing is the best around along with his experience with the fastest in the Porsche world
Eric Hood
dweymer 05-17-2005 07:44 PM
he is already in the go-to list...
camgrinder 05-17-2005 09:55 PM
IF you keep the boost under 1bar, the SC profile would be a nice choice. The SC will clear the pistons, it fits the 2.7 cam core nicely.
If you increase the boost and lower the compression ratio, the 964 profile will work. The 964 profile will require new billets.
dweymer 05-18-2005 04:42 AM
John, I was looking to run about .6bar, 9pounds; what would it cost to grind onto my 2.7's? PM me
