-   -   oops it went the wrong way (http://forums.pelicanparts.com/911-engine-rebuilding-forum/221999-oops-went-wrong-way.html)
Ken911 05-18-2005 02:44 AM
OK so I have the engine and tranny out to redo the clutch while it is out I decided to adjust the valves, this is the first time. I had already turned the engine back wards about a turn trying to get it to tdc when i read the next step in the directions that says only turn it clockwise. I'm hoping i didn't screw anything up. what gets damaged if the engine is rotated counterclockwise?
Porsche_monkey 05-18-2005 05:15 AM
I believe the problem is the chain tensioner doesn't work when you run in reversed, so you lose valve timing. If you didn't force it the engine should be fine. I think.
john walker's workshop 05-18-2005 08:00 AM
a non-problem.
Porsche_monkey 05-18-2005 08:14 AM
Since you have only 5 posts: Whatever John Walker says is correct.
kenikh 05-18-2005 10:40 AM
Yep. John Walker answering a question is like God speaking. You can take it on faith alone.
Glenn from Denv 05-18-2005 10:53 AM
...and the clouds parted and the angels sang and God hath spoken...
Ken911 05-18-2005 12:52 PM
thanks!!!
JeremyD 05-19-2005 09:41 AM
waaaaaaaaaaaaaa <--------angels singing........
john walker's workshop 05-19-2005 12:36 PM
oh jeezus!
Porsche_monkey 05-19-2005 12:41 PM
No! Oh God....
kenikh 05-19-2005 05:11 PM
...you devil.
dimps8 05-19-2005 06:15 PM
In case your vehicle is a 912:eek: it's easier to adjust valves counter clockwise, in that way you start at no.1 then 4, 3 and finally 2. you don't have to swap from side to side. Neat hey! but you don't have a 912 do you?;)
