-   -   3.2 to 3.4 cam settings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/222306-3-2-3-4-cam-settings.html)
nate3.4 05-19-2005 03:25 PM
8 years ago I had "sport" cams installed, along with other mods..."87" 911. Now my 3.2 to 3.4 conv. (9.5 to 1 JE by EBS) is almost complete and I lost the specs on the cams. They were from Windward in Putney Vt. They had "sport" stamped on them. Any ideas?
john walker's workshop 05-19-2005 03:39 PM
no clue. webcam can check the profile and recommend a setting. windward was a desk in a room, so they just sold other folk's stuff, and i hear they're gone now, sob!
camgrinder 05-19-2005 05:41 PM
The winward "Sport SC" cams are set at 1.8 to 2.0 mm. I would set them closer to 1.8 with the new pistons.
nate3.4 05-20-2005 04:42 AM
Was there a windward cam designated just "sport"? The porsche guy who installed them for me is recommending a setting of 1.5 but he doen't remember what the specs were either. Also other previous mods include B&B ssheaders and exhaust, larger throttle body/fuel pres. reg.,porting. Stock motronic, single plug.
ChrisBennet 05-20-2005 04:44 AM
Re: 3.2 to 3.4 cam settings
This is sort of off the topic but did you happen to CC the piston dome volumes of your JE "9.5:1" pistons yet? I got a set from EBS and they CC'd out to 10.5:1 compression. I sent them back and got another set of "9.5:1" JE's - those also CC'd out the same i.e. 10.5:1.
Those pistons were for a 3.0->3.2 conversion but you should make sure you check your compression before you put the motor together.
BTW: The EBS guys are great, I think this is a JE mixup.
-Chris
nate3.4 05-20-2005 04:54 AM
No, I think it's too late, this should be interesting, as we are almost done.
camgrinder 05-20-2005 08:38 AM
1.5 mm is fine. It may help with your possible 10.5-1 C/R too.
Every .2 is 1 degree of cam timing depending on how aggresive the cam profile is. In your case the cams are being retarded 2 degrees from the original setting. I am not aware of another version of a sport grind sold by Winward.
nate3.4 05-20-2005 05:01 PM
Thanks, Chris, John. We've pulled the cams and you are right CAMMASTER, they are "sport sc" and we moved in .1mm increments and checked the clearance to 1.7, and we are checking the dome vol. as well... thanks for the heads up Chris.
camgrinder 05-20-2005 09:21 PM
Your welcome.
