-   -   ITBs w/Motronic ECU, cam choices for 3.2 Carrera rebuilds (http://forums.pelicanparts.com/911-engine-rebuilding-forum/222622-itbs-w-motronic-ecu-cam-choices-3-2-carrera-rebuilds.html)
Shuie 05-21-2005 09:11 PM
Do ITBs gain anything over a stock Carrera intake if the Motronic ECU is retained?
Cam choice is what Im really curious about. I know I cant use anything hotter than a 20/21, 964, or 993 Supercup cam with the common plenum carerra intake due to fuel reversion issues. Can the Motronic ECU be chipped to use a hotter cam like a GE40, GE60, or GE80 if ITBs are used instead of the Carrera intake? Or would I need to go to full engine management if I wanted the hotter cam?
TIA
Steve@Rennsport 05-21-2005 09:23 PM
Sherman:
You may use any cam you wish with ITB's & Motronic.
The real issue here is that such combinations require custom mapping done on either an engine dyno or load-type chassis dyno and thats NOT cheap. Full engine management is easier for someone to build the maps needed to retain any semblance of durability.
camgrinder 05-21-2005 11:36 PM
The only other consideration is valve to piston clearances. The close lobe centers with some of these cams can cause a problem with V to P.
Shuie 05-22-2005 08:03 AM
Thanks guys. Great info as always
smdubovsky 05-23-2005 10:49 AM
How do you retain the motronics AFM w/ ITBs? Can it be chipped to do alpha-N or speed-density? Just curious...
SMD
