-   -   Oil Lines (http://forums.pelicanparts.com/911-engine-rebuilding-forum/223038-oil-lines.html)
Scott Wolthuis 05-24-2005 10:02 AM
Oil Lines
In the factory set-up...
The oil coming from the engine is first routed to the oil thermostat, at that point it either goes to the cooler or back to the oil tank or a mixture of both if the thermostat isn't fully open.
The thermostat has a pressure relief valve which will bypass the oil cooling circuit should it be restricted. So your oil pressure shouldn't drop. But you are burning power by maintaining a pressure adequate to hold open the relief spring due to the restricted oil line.
I repair 911 oil lines as a side/hobby...
I'm prepared to build some for the 73 cars from newer lines... Anyone interested?
Scott Wolthuis 05-24-2005 10:07 AM
OOOps
I meant for this to be a reply to the following-
http://forums.pelicanparts.com/911-engine-rebuilding-forum/222538-oil-lines-oil-pressure-loss.html
Can someone fix it?
