-   -   2.0L 911 crank main journal specs? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/223092-2-0l-911-crank-main-journal-specs.html)
cstreit 05-24-2005 02:52 PM
Does anyone have the acceptable specs for a 2.0L 911 crank main journal? I can't seem to find mine in the manual, page is missing apparently...
Both standard and under/oversize would be helpful.
thanks
304065 05-24-2005 03:57 PM
What year 2.0? The spec books list different tolerances for the early vs. late 2.0, not by much, but a couple small differences.
Late 2.0 66mm crank shown.
http://forums.pelicanparts.com/uploa...1116975428.jpg
cstreit 05-24-2005 04:55 PM
Mystery crank John.
However I measured it at 56.75 which puts it at .25mm undersize. The bearing saddles measure at 62.250 (I believe) and put them at .25mm over.
So now I know I need a .25mm over, .25mm under bearing set. Any idea where I can find one of them?
cstreit 05-24-2005 07:26 PM
Tried Pelican first of course! ...found some at EBS. Spendy bits the over/under ones. eep!
cstreit 05-24-2005 08:21 PM
...and now I found the spec book. always after i need it. :D
