Alan.UK's Avatar
Advice: SS 3.2 - rod bolts and springs
Hi,
The engine build for my SS 3.2 has started. The base motor is a 78 SC which was rebuilt recently and I have this stripped down but did not plan on splitting the case as it was rebuilt recently. This motor will be having s grind cams and brand new, 98mm barrels and pistons with 10.5:1cr, and 46 PMOs
My questions is with the and rod bolts and valve springs. I do not want to use stiffer springs unless necessary, due to the extra wear on the cams but after reading past posts it sounds like stiffer springs should be used. This motor will be rev'ed to make sure the cams are used (7200rpm) but not for long periods. Should I be changing the original but relatively new rod bolts for some ARP ones?
Thanks in advance for any advice
Alan.UK
Old 05-31-2005, 12:58 AM
I would rather be driving
jpnovak's Avatar
Alan, From what I have read the larger valves of an SC should use a stiffer spring compared to factory stock. This is to keep up with the extra mass (inertia) of the larger valves when using a high lift cam.
Camgrinder sells a sport spring and a race spring with Ti retainers. I think either one would be a good choice for your build. I will plan to use the race springs in my heads since I am putting an even bigger cam than you.
Old 05-31-2005, 07:27 AM
Alan.UK's Avatar
Thanks for the advice Jamie, I guess I should also fit ARP or Raceware rod bolts as well?
Thanks again
Alan
Always learning
Old 05-31-2005, 07:38 AM
jpnovak's Avatar
I think the stock SC rod bolts will be fine at that redline rpm. I will be using new stock rod bolts in my build. It was the smaller diameter 3.2 rod bolts that had problems with stretch at high rpm.
Old 05-31-2005, 03:38 PM
drag racing the short bus
dd74's Avatar
Re: Advice: SS 3.2 - rod bolts and springs
Alan.UK
I've heard the components in the stock valvetrain are good for 7300 RPM, so if you're getting up to 7200 for short bursts, I believe you should be fine.
Also, I don't think you'd have to change out the rod bolts. 3.0 rod bolts are more robust than 3.2s.
The Terror of Tiny Town
Old 05-31-2005, 08:16 PM
Alan.UK's Avatar
Thanks for the advice. I have bought some performance springs from John (Camgrinder) and after reading your responses I will be leaving the new "stock" rod bolts in place.
Thanks again
Alan.UK
Always learning
Old 06-01-2005, 12:09 AM
