-   -   300 Hp possible? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/223437-300-hp-possible.html)
kenikh 06-02-2005 09:05 AM
Originally posted by safe
Do you really have to ask?
I might be able to forgive it in a 912.
cgarr 06-02-2005 02:47 PM
But then it would not be a 912
Craig
http://forums.pelicanparts.com/uploa...1117748817.jpg
snowman 06-02-2005 08:40 PM
just pulling the chain to see what happens. Great response. No way would I put ANYTHING but a Porsche engine in a Porsche.
safe 06-03-2005 12:28 AM
You scared me there Snowman, I thought you were slipping...
jase007 06-03-2005 08:00 AM
Craig:
Purdy motor .... I've got one too but, its in a 356.
Jase
drsimonwong 06-05-2005 01:17 AM
I just bought Tony Corlett's book Porsche 911 3.2 Carrera and in th performance upgrade segment he talks about induction and exhaust mods.
" A Carrera with independent throttle bodies, a Motec EMS, 964 camshafts and an SSI exhaust should make close to 20 hp. Add in "S" camshafts and racing pistons and the Carrera 3.2 engine is good for 300-320 hp!"
Granted this is for the Euro spec cars with 10.3:1 compression and no cat.
Question, when he talks about 'independent throttle bodies' does he mean carbs ie PMO's or Webbers?
Simon
drsimonwong 06-05-2005 01:19 AM
Oops I think I wrote 20hp when I meant 280hp.
Simon
YTNUKLR 06-05-2005 02:05 AM
Independent throttles are anything that have a butterfly for each cylinder.
For example, MFI, PMO's, Webers, TWM, etc. are all independent throttle bodies.
The 3.2 has one big throttle body stock.
BTW, when you calculate the cost of Motec($$$), $800 SSI's, and racing pistons (then you might as well make it 3.4L...), you are really upside down in that motor compared to a good 3.6L from a later 911.
Porschekid962 06-05-2005 03:11 AM
as per bruce andersons book, 3.2 ss motor off a 3.0. head work(big ports) ge 80 cams, 46 webers, rsr racing headers (im sure you could substitute 993 heat exchangers for this or b&b.) page 152. motor makes 325+ at 7500rpm. fun stuff
drsimonwong 06-05-2005 05:24 AM
A lot of these upgrades were developed well over a decade ago when 3.6's were not available so they have a different appeal to a similarly priced conversion.
Here in Oz there seem to be a lot more carb'ed 3.0 and 3.2 engines pumping out big horsepower compared to 3.6 conversions. Perhaps many of the older mechanics just liked building there own hotrods.
Simon
