Cam regrind ??
Hi all,
do you need to harden the cams after a regrind ?? 1 of my lobes was worn 1/4" and had to be rebuilt, couple of other had pitting on the lobes cheers hayden Pearce 74 911 targa |
Porsche 911 cams are chill cast. The factory hardness goes deep enough to regrind and remove the normal pitting. The lobe worn 1/4 inch would have to be welded. The common welding material finishes at 58rc hardness. very close to the factory spec.
No additional heat treat is required. |
Don't forget to have the cam followers resurfaced or you will be regringing cams very soon.
| All times are GMT -8. The time now is 08:40 AM. |
