-   -   Advice on Deck Ht, Comp ration and Shims for my 3.0 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/224742-advice-deck-ht-comp-ration-shims-my-3-0-a.html)
tom1394racing 10-24-2005 02:17 AM
John
Sent you a PM.
JohnJL 10-24-2005 04:02 PM
Got it, thanks.
BTW, I seem to remember from my 993 ownership days they have a compression up around 11:1, right?
tom1394racing 10-24-2005 04:14 PM
That's right, but they also have knock sensors that will retard the timing in any cylinder that is about to detonate.
Our older engines are limited to about 9:5:1 for single plug and 10:5:1 for twin plug if you run pump gas (93 octane).
ChrisBennet 10-24-2005 04:28 PM
Originally posted by JohnJL
Got it, thanks.
The 964's had a stated compression of 11.1:1 if I recall.
I've only measured one 964 motor and the true compression was around 10.4:1.
-Chris
JohnJL 10-26-2005 06:26 AM
Yes, went back and checked, 11.3:1 in GT Purely Porsche...and some are supercharging on top of that.
One knock sensor per bank?
ChrisBennet 10-26-2005 06:41 AM
I don't doubt that. The point I was trying to make is that true compression ratio of these Porsche motors is make less than the stated compression. You cannot use the factory compression numbers as guide to what is "safe".
Knock sensors: Yes, one per bank with a "bridge" arrangement between the bases of the cylinders to a shared notch sensor.
-Chris
