-   -   factory steel head stud reuse (http://forums.pelicanparts.com/911-engine-rebuilding-forum/224828-factory-steel-head-stud-reuse.html)
philippeF 06-05-2005 05:00 AM
Hi
may you give me your opinion:
shall i reuse the steel head studs after teardown ?
i mean, they could have been a bit stressed during tear down operation (using snap on removal tool).
what do you think about it ?
(case savers to be installed in a mag case)
best regards
Philippe
afterburn 549 06-05-2005 08:17 AM
the steel ones are now pronouced "better" and are cheap enough..replace,cheap insurance.......very hard to do in car.......tear dwn again.
john walker's workshop 06-05-2005 08:29 AM
if their threads didn't get damaged from removal, i see no reason why they could not be reused.
afterburn 549 06-05-2005 09:34 AM
the only thing I am thinking is if they have been there 10 yrs or so....might be a good time to do it
sammyg2 06-05-2005 12:48 PM
no reason to replace em unless they are damaged.
If they haven't seen extreme corrosion or over-stressing they will last longer than the car.
afterburn 549 06-05-2005 01:16 PM
well John for sure ought to know, I was under the thought they sort of had a t.b.o.
john walker's workshop 06-05-2005 03:52 PM
after you use a bench grinder wire brush on them, they usually look like new. any pitted ones should obviously be replaced.
kstylianos 06-05-2005 07:38 PM
Walt at CE using the same procedure, but media blasts the studs. If they look ok he paints the studs (not threads) to prevent rust/corrision, etc.
philippeF 06-06-2005 03:06 AM
thanks
Philippe
