-   -   Priming Oil System (http://forums.pelicanparts.com/911-engine-rebuilding-forum/225060-priming-oil-system.html)
DSM 06-06-2005 12:52 PM
Priming Oil System
Hi,
I'm new to this forum and actually just got my 1983 euro slantnose cab back from the body shop after 5 years. It's a long story.... Away the car hasn't been run in that long period of time & I want your advise on how to prime the oil system. Please give your thoughts on what I should do before startup.
Dante
http://forums.pelicanparts.com/uploads5/41118087510.jpg
briankeithsmith 06-06-2005 01:18 PM
Disconnect the ignition, fill it fill of oil and turn the engine over using the starter until you get 2.5 to 3 bar of oil pressure on the gauge.
Then reconnect the ignition and fire it up.
Brian
