closing chain housing, sealant or not????
Hi,
I'm in the fase that i'm closing the chain tensioner housings. In Wayne's book he states that all that's used is a gasket between the covers & housing. On a lot of 911's I saw that an additional sealant was used. (574 or some silicone based sealant). Is this a proven procedure to assure a leak free engine? Is the gasket alone not enough? If so, what's the best product to use? 574, Dirko or Curil T? Thanks Hessel |
I put mine in dry and to date I have no leaks.
Kevin |
I used a very thin film of hylomar on mine with no leaks.
I have a hard time installing paper gaskets dry. Some times it is necessary, more often it is not. I would not use RTV but that is a personal preference. |
| All times are GMT -8. The time now is 02:48 PM. |
