cam timing 120/104 web cams?
Webcam's site does not show any info on cam lobe centers or set up timing. Can anyone help?
thanks! dave |
Thanks to Steve Weiner at Rennsport for the help!
db |
The answer is 5.2mm. Just posting the info to help anyone if they find this thread while doing a search.
Dave & Tyson:
Good talking with you today and happy to help, anytime...:) Lobe centers are 100 deg; I & E. |
I had good results by advancing the 120/104 cam slightly past 5.2. The HP curve goes right off the charts on my 3L and this moved it down slightly. In retrospect I think I got the wrong grind...
Thanks guys!
These cams replaced the 906 grind that came in Dave's motor. What possesed Dave to buy a full-on race motor for his street/track 914/6 is beyond me. (Errrr, no it isn't :D ) These cams are much more responsive at lower revs, but I've got some more carb tuning ahead of me to get the top-end where it should be. Should be a screamer when she's dialed-in. Thanks again Steve! |
| All times are GMT -8. The time now is 08:53 AM. |
