Crank Scoring
Okay, I think I'm just freaking out but I just wanted a little check.
I just pulled my crank. There are a few minor scores. Barely enough to hang a fingernail on. They are only on two journals. 1 rod 1 main, only a single line on each. Crank measures well other than this. Should I be concerned? |
I had the same thing on my engine and put it back together with new bearings. No problems 1 year later. If you think about how big the bearing surface is and how small the scratches are you don't really have to worry about it.
-Andy |
HI...
If you are in any way concearned. Have it micro polished. It will save a lot more in the long run. $60.00 VS 6000.00 KO... Good luck
If you feel the scratch with your fingernail, it would be a good idea to have it micropolished. Be careful who you take it to. Good luck.
BTW, I know where you can score some crank.
Just kidding. :) |
| All times are GMT -8. The time now is 08:10 PM. |
