-   -   Sparkplugs and oilfilters (http://forums.pelicanparts.com/911-engine-rebuilding-forum/226089-sparkplugs-oilfilters.html)
P Clingman 06-13-2005 02:39 AM
Hi I wondered what the best spark plug was for a 3.2 stock class
race engine I have been using Bosch platinum r3 ? Also whats
the best flowing oil filter? I have been using Fram because they are easy to get am I missing out on some filtering? Has anybody
had any experience with the take apart style filters? And last
question are the filter magnets worth using. I am just finishing
reassembling my engine after a spun bearing and want the best
filtration possible. Thanks Palmer
cstreit 06-13-2005 09:24 AM
Don't waste your money on platinum or fancy tipped plugs. Standard copper single electrode plugs work best. I'm partial to NGK but don't have specific #'s for your application.
Steve@Rennsport 06-13-2005 11:56 AM
Never,....EVER,..use a Fram filter on a 911.
I have a large garbage bag of American filters that I've removed from 911's over the year to show people what happens. The cases are split, ballooned; the elements shift, and there are no anti-drainback valves on these things. Remember, when a filter fails on these cars, you cannot see the trail of oil until its far too late.
IMHO, these engines are too damned expensive to risk by using a cheap and inadequate oil filter. Use the factory ones (Mahle-Mann) and you will be better off.
cnavarro 06-13-2005 01:02 PM
Beru Silverstones are a good non-resistor plug. I also use the NGK iridium resistor plugs too on my '70 911T with excellent results. I'm going to pull them out after my drive from Chicago to Hershey for Porsche Parade and see how they look.
I'm a big fan of the mobil 1, amsoil, and K&N oil filters. All have very well constructed housings, anti-drainback valves, and synthetic media which offers better filteration without the restriction of a paper element (as with the pureolator pureone elements which are known to clog up in 3+ K miles).
Jared at Pelican Parts 06-13-2005 01:16 PM
Factory filters only i.e. Bosch, Mann or Mahle
as for plugs, platinums are a waste of money, regular Bosch Supers are fine, NGK are good as well...
DO NOT use Fram
P Clingman 06-13-2005 05:14 PM
Thanks for the info. I will use Mahle now. I have been cutting the filters
after every track avent and have never saw a problem with them and only saw stuff in them after a engine failure. Has anybody used filter
magnets? I agree theses engines are to expensive skimp on . Thanks again Palmer
Jeff Alton 06-14-2005 12:26 AM
The NGK number for a 3.2 is a BPR6ES
JEff
CarreraUK 06-17-2005 09:11 AM
In the uk the NGK catalogue only lists B8EGV for the 3.2 hope that helps!
Jeff Alton 06-17-2005 07:33 PM
The BPR6es is the number you get when you cross reference with the Bosch WR7DC. I have used them for years....
Jeff
