Oil Cooler Leak
Hi
After 5K post rebuild my 2.4 has developed a leak between the case and the oil cooler, I used curil-t on the 'o' rings but this obviously hasn't sealed.
Any suggestions (re re sealing it)
Neven
Old 06-14-2005, 02:50 AM
ChrisBennet's Avatar
The Curit T on the O-rings probably isn't helping things. Are you sure it is the oil cooler seals that are leaking? I've just never seen a leaking oil cooler seal. I probably just haven't worked on enough motors though.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 06-14-2005, 06:18 AM
magic930's Avatar
My oil cooler leaked the first time using curil-t on new seals, the second time installed seals clean and dry and it has not had problems. ( get new seals, once they are compressed once they won't seal again properly)
Old 06-15-2005, 10:04 AM
Thanks 'Magic'
I need to do a 5000K service (torque heads etc), So I'll replace them then, Did you do itwith the engine in the car?
Neven
Old 06-15-2005, 12:47 PM
magic930's Avatar
No I took it out. It is difficult to get the oil cooler off in the car (but not impossible)
Old 06-15-2005, 12:55 PM
D troop 3/5 CAV ,162 AHC
afterburn 549's Avatar
I am gonna be a butt and bet it is not your cooler but a sender up an top by the thermistat.
Old 06-15-2005, 10:01 PM
Jeff Alton's Avatar
Even new idiot light switches can leak, ask me how I know! I now JB weld the red plastic part of the switch to the metal part on new switches to help prevent leaks there. Never had one leak doing it that way, but then again, I only saw one new one leak too! As for the oil cooler seals, do not put anything on them, they will work better installed dry. And Chris, you probably HAVE worked on enough engines!!
Jeff
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 06-15-2005, 11:05 PM
