Valve covers, torque?
Two questions from a flat-six newbie: is the "turbo" valve cover upgrade really worth it (2.4 NOT currently leaking)? and.....what should the covers be torqued to (original and turbo type)?
Thanks, Randy
Old 06-20-2005, 03:46 PM
walt's Avatar
If they aren't leaking I would wait as you have nothing to gain. The torque spec is 6 ft lbs regardless of the type cover.
Walt
82SC 3.0
81SC 3.6
Old 06-20-2005, 04:44 PM
Thanks walt...as I am about to do a valve adjust, I thought this might be the time to upgrade rather than risk creating a leak...it also has been suggested that the upgraded covers provide some additional cooling. Does this make sense?
Old 06-20-2005, 05:44 PM
Warren Hall Student
Bobboloo's Avatar
Any additional cooling they do would have to be minimal because the gasket creates a thermal barrier between them and the cam tower but atleast they can only help.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 06-21-2005, 10:36 PM
