 Pressure fed tensioner saftey stops
		Hi all I just modified my pressure fed tensioners with a tube under
	the piston to stop it from collapsing completely if it fails. Has anybody else done this I got the how to info from EBS I made a 7 mm tube to fit in there. My chains seem tight now tho not as tight as when I adj cam timing I can move the chains up and down about a 1/2" where they go over the ramps and the engine turns over easily not tight like when you adj cams. I still have about 15mm of travel left in the tensioners.My question is is how tight is to tight my chains are new how much do they stretch? thanks Palmer  |
| All times are GMT -8. The time now is 07:22 PM. |
