-   -   points self tapped into distributor - help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/226979-points-self-tapped-into-distributor-help.html)
1967911s 06-18-2005 01:51 AM
just got 1968 2.0s back from mechanic and he has used a self tapping screw to secure the points to the distributor, whilst this works, I can't imagine is a good long term solution.
what are people's thoughts, i'm assuming that i can buy replacement parts to fix this, and may need a new distributor A-602-021-50 - $$$, no longer available...
is the AMD option a solution?
many thanks Rich
