Airbox instl question
I am installing a new airbox on my 79SC. The old box had the drain filled with sealer. I wonder if this is correct or should the drain be open? Should there be a hose attached to the drain, and if so, where would it go? Thanks.
I know someone knows the answer. The hole in question is right below the air filter and is about 3/16" in dia.
| All times are GMT -8. The time now is 06:46 PM. |
