-   -   Damage inside engine case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/228138-damage-inside-engine-case.html)
JohnJL 06-25-2005 05:00 AM
Damage inside engine case...pics
I cracked open my 3.0 case today and found this....the engine was assembled from many donors, so don't know what happened here, but check out what appears to be a hole worn into the aluminum case, revealing what feels like hard black/brown plastic underneath.
Anyone know what that is, what's underneath, if this is a problem?http://forums.pelicanparts.com/uploa...1119700768.jpg
asphaltgambler 06-26-2005 04:25 PM
Isn't that the rear oil passage where the pressure relief assy goes into?
Don Settergren 06-26-2005 06:26 PM
I think asphaltgambler is right, but to be sure, take a wider shot and submit it.
Fishcop 06-27-2005 04:36 AM
They all do it... it's apparently not an issue. Mine was the same, no problem.
JohnJL 06-28-2005 04:06 AM
Here's a better pic
Here's a wider aspect...just to the right of the damage is the thermostat.
thankshttp://forums.pelicanparts.com/uploa...1119956774.jpg
briankeithsmith 06-28-2005 06:40 AM
My 930 case has that, and a 964 case I just opened has the exact same thing. Therefore I assumed that was there purposefully as part of the casting/manufacture process.
Brian
asphaltgambler 06-28-2005 04:27 PM
I dunno, to me it looks like a plastic or plastic composite sleeve /insert. Mine looks bubbled, about ready to break. It must have a purpose or it wouldn't be there. Maybe some engine 'gurus' could help us. I want to know.
Fishcop 06-28-2005 06:36 PM
Do a bit of a search... it has come up quite few times with engine rebuild newbies ;)
It looks rough, but it is factory.
asphaltgambler 06-28-2005 07:30 PM
what search words / phrase?
Fishcop 06-29-2005 04:12 AM
Fine, don't believe me... :)
http://forums.pelicanparts.com/showthread.php?s=&threadid=153820&highlight=oil+ho le+case
http://forums.pelicanparts.com/911-engine-rebuilding-forum/154347-up-porsche-standards.html
And the quote from Tyson is "There's nothing wrong with your case. That's totally normal. If you want to, you can epoxy the external portions for oil leak prevention."
JohnJL 06-29-2005 08:03 PM
Thanks a lot guys. I think I'll leave mine alone, I'd be concerned about having a piece of of epoxy break loose in the case...
john
Sumotang 06-29-2005 08:04 PM
Hey John
Are you in Sutherland Shire? If so where abouts?
JohnJL 06-29-2005 08:10 PM
I work in Sydney CBD, live in Mosman...Australia IS the Shire to the rest of the world!
Sumotang 06-30-2005 06:36 PM
Why is Australia the Shire to the rest of the world??? Enlighten me.
JohnJL 07-03-2005 01:33 AM
cuz its nowhere near anything else. And thats a good thing.
Except for NZ, I guess that's farther.
Nitrometano 07-14-2005 10:51 PM
Mine dont have that hole.
NevenM 07-19-2005 01:25 PM
Guys
Well actually NZ has stolen the Shire thing post Lord of the Rings or is that the Middle Earth?.
Another reason is that:
Aussie = Shire
US = County?
NZ = Borough/County
I'm sure someone will correct me on this
Neven (in the Middle Earth)
JohnJL 07-20-2005 05:30 AM
Both are awesome. I'm lucky to be here and have business reasons to get to NZ regularly.
