-   -   Help - Cam Nut Torque During Dry Piston to Valve Clearance Check (http://forums.pelicanparts.com/911-engine-rebuilding-forum/228161-help-cam-nut-torque-during-dry-piston-valve-clearance-check.html)
tom1394racing 06-25-2005 09:11 AM
I am in the process of doing the dry check on piston to valve clearance on my on a 3.0 SC with 10:1 RSR pistons and a GE60 cams. As this is my first 911 rebuild I am following Wayne's book very carefully.
I have just completed the cam timing and everything seemed to go well with the 5.0 mm intake timing setting for both cams. I did deviate from Wayne's recommendation to torque the cam nuts up to final torque of 110 ft-lbs. I only torqued them to around 60-70 ft-lbs based on "wrench feel".
Since I will be disassembling the heads, cam towers etc to do the final assembly with the sealants and gaskets, I did not think it was necessary to torque the cam nuts to the final value just to check the timing and clearance. I can't see how cam nut torque would effect the timing for the cams.
Can I get away with this and torque the cam nuts to their final value only once during final assembly?
camgrinder 06-25-2005 09:15 AM
Your fine Tom.
viejopatron 06-25-2005 03:33 PM
Thank the lord. Tom, I'm at this same stage and was wondering as well.
Hey John - I just sent you a PM regarding the profile you did for me.
