-   -   Cam tower spray bar steps (http://forums.pelicanparts.com/911-engine-rebuilding-forum/228216-cam-tower-spray-bar-steps.html)
JohnJL 06-25-2005 06:40 PM
Thanks to everyone who posted on this previously. I would appreciate it if someone would confirm the steps for removing the spray bar in an 83 3.0 head. Is it just drill out/tap/pull the two plugs I am pointing to in the pics below? THere were some references to "location pins" in some past threads that I didn't understand.
http://forums.pelicanparts.com/uploa...1119749953.jpg http://forums.pelicanparts.com/uploa...1119749999.jpg
afterburn 549 06-25-2005 10:08 PM
yup
Fishcop 06-26-2005 06:20 AM
That's it. New ones are very cheap from Porsche
afterburn 549 06-26-2005 05:37 PM
As for me I tapped and put in pipe plugs for two reasons, can take it out with no fuss,and seems more fool proof then plugs.
ChrisBennet 06-27-2005 04:36 PM
There are "locating pins" part way down the tube that hold it in place. I've never removed the spray bars, I just R&R the plugs and clean them in place.
-Chris
Fishcop 06-27-2005 05:21 PM
You're right Chris. Those pins have (I think) a 8mm hex head and must be turned out before pulling the bars out.
afterburn 549 06-27-2005 06:44 PM
all thats true,just remember there is a right side up, and dwn to them, should you elect to take them out.
