-   -   Cam timing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/228297-cam-timing.html)
TargaT 06-26-2005 12:46 PM
Cam timing
Hello, when setting the .1mm rocker clearance on #4, where should the cam dot be facing? up or down?
Thanks, Joe
ChrisBennet 06-27-2005 04:15 AM
Down. The writing on the end of both cams will be upside down when setting the valve clearance for #4.
-Chris
TargaT 06-27-2005 06:19 AM
Thanks Chris,
Waynes description of this process in his book is not clear at all.
Joe
hcoles 06-27-2005 11:03 AM
I think it is safe to set the 0.1mm in all cases with the pad on the rocker as far away as possible from the "nose" of the cam..this means the the "nose" is on the other side of the cam axis from the rocker pad.
Camgrinder....please correct me if I'm wrong but I think there is a long period of "dewel" on the back side of the cam where the clearance/"lift" is constant or I guess we could say the lift is zero. I've always assumed this
camgrinder 06-27-2005 01:02 PM
Hc you are correct, on most street cams the majority of the base circle is at 0 lift. Some racing cams start to lift the cam on the base circle, so setting the valve lash should be done in the center of the base circle.
