2.3 litre - how to?
i went to watch some historic racing on the weekend. one guy was running a 911ST replica with a 2.3 litre motor.
anyone know what crank/rod/barrel etc combo results in a 2.3? |
Hi Ryan
My tangerine 911 had a "2.3" - 66mm crank with 85 mm JE pistons in bored Nickasil jugs. Actually closer to 2.2 - 2245cc if I remember correctly. P.S any idea if I changed my red car back to an ST look - would it be eligible for historic racing with its 72 2.4E motor or do they have to be all numbers matching to be eligible? Robert |
hey rob
where the 85mm pistons a custom order? there are 2 main historic classes for 911's. the first is group S (Sa, Sb & Sc divided by age). group S requires cars to be all original (ie. no replica's) and is dominated by MFI 74/75 2.7 Carrera's. The odd Carrera3.0's do ok also but are a bit limited by having to run CIS - and thus can't run hot cams etc. I think a 2.4E would do ok in sub group Sb - at least you could compete in the sub group... your red car would have to fully match its chassis no. to get a group S logbook the other option is group Nc - for historic touring cars that ran back in the day. replica's are allowed but the only 911's that ran in the day were 2.3 ST's. there was one group N 911 at the historics on the weekend - it went well but has to contend with mega hp camaro's etc. your red car would need to be a 2.3 and early bumpers to run as an ST check out http://www.hsrca.org.au/ for more info |
Ryan
Thanks for the info. I got the 85mm pistons from EBS - I think pretty standard issue for them. Robert |
rob
and the barrels were stock 2.2 bored out by an extra mm? |
Yup - but std. 84mm Biral (not Nickasil mistakenly typed in my first reply), bored to specs supplied by EBS.
Robert |
Ryan,
was it a newly builty 911ST running or was it the one that has been around for a while. Michael |
mike, its a new one - silver - this was its 1st race meeting
there's some pics on the aussie pelican board |
| All times are GMT -8. The time now is 11:29 PM. |
