VFR750's Avatar
Actually, because it's been done successfully since the 1970s there is a HUGE body of data that supports it's success. You just will never find it
It seems to be a recent phenomenon that historical data and experts are getting challenged in a way that is impossible to defend. You can't provide data because there was no means to record it like there is today. So the absence of the (undocumented by today's internet standard) information MUST mean it is totally unbelievable.
Sad really. It's so much easier to consult history and experts, than recreate it.
I just wish I had seen this post before I buttoned up the bottom end. It would have been very easy for Armondo at CCR to cross drill while he was welding my crank. Too late!! Darn.
Old 03-08-2016, 02:21 PM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by nismo silvia View Post
I would like to see how long these engines last since cross drilling is a big no no also so is having a grove all the way around the crank shaft.
I am not sure what benefit you think you are adding but I have a feeling all of your cranks are blue by now.
Said you. Hilarious.
When the guys who have been doing this for forty plus years, the guys who build the best, hardest ridden motors on the planet condone something, you should listen. Unqualified platitudes are silly.
Perhaps this doesn't fly for Nissans given your assertions and alias, but in Porsches, it's all good.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-08-2016, 03:21 PM
Cross drilling can be quite effective if it is done properly and crank designers have the situation under hand, I am sure companies like Braynt Crank have great designs and solutions. The problem with all due respect to to the science of tribology is to ultimately cool the bearing with an adequate supply of oil.
It can be a shock to some folks to realize that a lower oil pressure can be beneficial if it is the result of more clearance, clearance has solved more bearing problems than modifying passages, to much clearance is always better than to little. Ask any serious engine builders the conversation can be very interesting.
Old 03-08-2016, 08:53 PM
Amateur
pmax's Avatar
Of course, but ...
perhaps the Porsche experts can throw us neophytes a bone to chew on.
What's the physics and best practices behind the mod ?
I don't need that.
Old 03-08-2016, 10:30 PM
Banned
Pmax, if you do a search in this forum for "crank cross-drilling" (different than "Kenik's cross-dressing" ) , you will find plenty to read on the physics and best practices.
PS - that nismo dude doesn't know what he's talking about.
Old 03-08-2016, 11:20 PM
VFR750's Avatar
I think the physics behind this particular mod is pretty basic: at high rpm, the flow of oil to the middle of the crank is less than needed to offset the heat and bearing load.
We are fine at 6500 rpm. But these guys are pushing past 8000 rpm.
So the physics are: add a source oil oil pressure to the middle of the crank. Thus
It is easier to get oil pressure along the whole crank.
I think you have to think about the 911 crank. It is a 7 bearing main. Long! And 8 journals plus 6 rods to feed. Lots of oil needed.
So experience with failed 2/5 bearings in race engines showed the need for more oil. Simple observational learning. Simple fix actually. Just not needed for street engines kept to reasonable rpm.
Old 03-09-2016, 03:14 AM
One other aspect of the physics part. At high rpm the centrifugal force acting on the oil in the crank can force the oil out at a rate that may exceed the stock pump's capacity, esp. when running clearances on the high side.
Old 03-09-2016, 07:57 AM
VFR750's Avatar
Also the physics of just moving the oil.
Getting the oil to change from a pure radial flow in the case, to circular flow in the gap, and then jumping to a rotating crankshaft, with centrifugal load from the oil column increases the losses as rpm go up.
More flow and pressure help. So does a "shortcut" with an added supply in the center. As long as the pump can keep the pressure high, while satisfying the flow rate it seems to be a good thing.
Old 03-09-2016, 08:46 AM
The majority of the problems associated with Porsche racing engines and Street based components that are used in the majority of cases is that the matching of revs and the appropriate braking are sometimes at odd with one another. This throws the Rod assembly into a tensile not a compression situatation and the big end of the rod is no longer as round as it is intended to be, that is why eccentricy clearance is built into the brg. If stock clearances are used even when the eccentricy and cross drilling is employed the big end of the Rod will swipe the journal and trouble starts disaster ensues that is why Engine builders use between .0007 and .001 additional clearance on the journals. And all this is a little more intensified by the center two Rods being the last to get supply, it started with Ritchey Ginther who used to have Harold die grind nothches at the parting lines to use the 2.0 911 stock crank and rods to retain oil and it is still true today.
The GT3 RSR are cross drilled and have a essentailly a cross drilled or two larger holes at the very front of the crank in the nose bearing and generous clearance but are other than that are pretty stock in apearance with out groving mains and knife edging etc. I don't understand why someone would weaken a shaft by undermining the area that receives the Torsional excitation.
But never the less these practices have apparently helped builders and reduced the amount of measuring necessary for a sucessful power plant.
regards
Old 03-09-2016, 09:00 AM
Chain fence eating turbo
I would like to see one of these setups after a race or even 10-20 thousand miles, post up some pics. Also just because it has been done since the 70's doesn't make it right.
El... oh.. el
Old 03-09-2016, 11:16 AM
kenikh's Avatar
^ could it be because the cranks work so well they don't removed all that often? Could be...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-09-2016, 11:42 AM
There's 8 bearings! Compare to your average American V8 that only has 5 bearings, the H6 is plenty robust.
Old 03-09-2016, 12:53 PM
San Ramon, CA
eastbay's Avatar
LOL, I sent a crank for polish and it came back polished and drilled
Old 03-09-2016, 08:17 PM
AlfonsoR's Avatar
Rob, how many miles have you put on this engine (post #7)? If it were me, I would be worried about the size of the hole compared to the others. It looks way bigger. But if you've run the thing 200k miles, then obviously somethings are entirely over thought (me).
"Simplicity is supreme excellence" - James Watt
Old 03-17-2016, 11:11 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The hole is larger to promote additional oil flow to the #4 main bearing.
All other holes are just feeding a single main journal/bearing where the #4 hole is flowing additional oil to feed the adjacent (#2 & #5) rods.
The feed hole is probably slightly larger than it needs to be but I really don't see a down side.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-18-2016, 01:36 PM
AlfonsoR's Avatar
Thanks Henry.
Old 03-18-2016, 04:31 PM
Can someone provide roughly what this costs?
I may groove the bearings myself. I like the jig posted.
Never mind, I see Ollie's charges about $130. Not bad.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-09-2017, 10:00 AM
KTL KTL is offline
Schleprock
KTL's Avatar
In case you're curious, the thread linked below includes some pictures to indicate what goes into cross drilling the crank
Another crank cross drill question
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 03-09-2017, 01:41 PM
prschmn's Avatar
I wanna know what a "NISMO" type is doing on a Porsche forum.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
97 Van dieman F2000-gone but not forgotten
30 plus years of rebuilding services
Old 03-09-2017, 04:08 PM
Trying learn something about SUCCESSFUL race cars maybe.
97 2.5 Boxster, 78 911SC, '06 H-D Street Bob, '07 Audi S4 (daily driver)
Old 03-09-2017, 04:32 PM
Tags
cross drill crank
