-   -   opening case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/231321-opening-case.html)
starlifter1 07-15-2005 04:25 PM
opening case
To install a 964 distributor you need to change the gear on the crank and for this you will need to open the case? must I go through all the machining as If I were doing a total rebuild? should I just do a total rebuild? Can you open the case, replace that gear and close it without changing anything?
This started as a top end but I started changing things
1983 911SC 3.0 with less than 100,000
Steve@Rennsport 07-15-2005 06:55 PM
Indeed, the crank gear must match the one on the distributor so if you want to use the 3.6 dual-dizzy, you should install the 3.6 crank gear (about $ 65).
The crankshaft must be removed so the cases must be opened up.
Jeff Alton 07-15-2005 07:31 PM
I have the complete intermediate shaft if you are interested...
Jeff
starlifter1 07-15-2005 07:54 PM
intermediate shaft ?????
