mingmong's Avatar
Stainless Steel Exhaust Studs?
Got these from the local shop. They're stainless steel exhaust studs which the shop assured me where better than the normal mild steel ones. I thought that stainless steel and aluminium reacted badly together? Should I install them or not?
Cheers Mark
Old 07-29-2005, 11:58 AM
Not all stainless is equal. I'd install with antiseize. Stainless set screws might be an option since they have a hex drive on one end.
Sherwood
Old 07-29-2005, 12:02 PM
Unregistered
sammyg2's Avatar
Install them with a coating of phillips milk of magnesia, they will last forever and come out easily if you ever need to take them out.
Make sure you use it on the nuts also.
Old 07-29-2005, 12:12 PM
mingmong's Avatar
Cheers guys...installing with antiseize paste shall commence henceforth!
M
Old 07-29-2005, 12:18 PM
abit off center
cgarr's Avatar
Just dont use stainless steel nuts when you put the exhaust on or you may never get it apart!!
Craig
______________________
Craig
G2Performance
Old 07-29-2005, 12:25 PM
