-   -   oil cooler question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/233670-oil-cooler-question.html)
sylvester 07-30-2005 01:27 PM
oil cooler question
hi... can someone tell me where is the front oil cooler located on a 1979 porsche 911 i look but didnt find it, im lost thanks
pyro57 07-30-2005 02:20 PM
Look in the passenger side wheel well. It's shaped like a trombone.
Good luck, Dave
BReyes 07-30-2005 06:44 PM
Front oil cooler you ask? It is good you asked, because on the 79, you will benefit by looking into this topic further. What you have works ok, and it may be upgraded. If was going to keep the car, I would swap out for a carrera cooler with a fan, to keep the motor a little cooler.
Have you the upgraded tensioner/cam oil line?
Regards,
