Pressure plate
Does anyone know the torque settings for a 1988 3.2 G50 pressure plate bolts? I have a manual here that says 80 lb-ft. Surely that cant be correct? Thanks
Old 08-04-2005, 02:16 AM
Pressure plate bolts - M8 - 18.4 ft-lbs - this is what most M8's are unless it is a special application - Page 200 - Wayne bible
Please double check with other sources, this is what's on page 200.
-h
1989 3.2 coupe, DIY top end at 77k, now 112k
Old 08-04-2005, 07:01 PM
Don't forget to install the starter ring and get a new pilot bearing mounted flush if you are planning to change that. You will think there is two starter rings....there isn't... one is a engine speed sensor ring.
-h
Old 08-04-2005, 07:04 PM
