Starter bolt on transmission
I am in the process of engine removal using the process identified in Wayne's book (101 projects 911). I have removed three of the 4 transmission nuts, but the hex head bolt where the starter is mounted is stripped.
Any recommendations on the best wat to remove this bolt. Any suggestions would be appreciated.
mike
75 911S
Old 08-11-2005, 03:17 PM
A grinding or cutting wheel for a dremel may fit up there. No way to get an angle grinder in. I think you're in for a long job there.
-Brian
Old 08-11-2005, 04:07 PM
Jeff Alton's Avatar
I had this problem once, that is why I pull the motor and tranny together. I ended up doing that as I could not see how I was going to get it off. The worst part was some jack@ss mechanic at a well known p-car shop here had just put a new clutch in it and stripped the head off that one barrel nut. Wonder if they shoulda replaced the 50c nut.........
Jeff
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 08-11-2005, 05:08 PM
