Wer bremst verliert
Fiberglass won't set
I did some minor repairs with a fiberglass paste with a 1:50 catalyst according to directions. The instructions say it should set in 2 hours. Its 3 days later now and still a bit tacky. Is there a way to force the cure? I think it might have been a little too cool (~60 degrees?) for the first 2 days. I thought I estimated the catalyst amount right...it looked the right pastel color (paste was tan and the catalyst is red)
Its porsche & technical! ...these are minor repairs on the air shroud around the 'captive nuts' and a crack I had around the #6 intake. Thanks
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Ultraviolet light helps-the sun.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
MBruns for President
Sun and heat.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
It should have set by now. Did you mix by weight or volume? Most resins are by volume. May have to grind it out and start over. Resins are very sensitive to changes in hardener, 10% either way is about the max.
Donnie Currently Porsche-less.....
JohnJL,
Which f/g repair product did you use? I want to repair my shroud this winter.
Bill G. '68 911 Ossi Blue coupe |
3 restos WIP = psycho
If the resin or catalyst was old, that might have caused it. I think the 10% variance is for ideal setting, but even if you were below that polymerization should have happened by now. My bet is you got some bunk resin/catalyst. I've over and under kicked polyesther resins (paste and liquid) and never had problems with setting unless it was really old.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Wer bremst verliert
Thanks guys.
I am using "Septone" fiberglass paste & hardener. Looked fairly new...will try the heat and light and see it that works.
My money's on old hardner.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
If it hasn't cooked off now - it probably not going to. I would grind off and use west system epoxy. Get from any boat supply place.
