-   -   How could I not realize that.... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/236784-how-could-i-not-realize.html)
safe 08-23-2005 08:24 AM
Re: Re: How could I not realize that....
Originally posted by Steve@Rennsport
A dyno test would have shown a loss in low & mid-range torque with all those broken rings. Peak HP is not affected very much depending on many factors,....:)
So an worn old tired engine could still have most of itīs horses left, at least peak?
Steve@Rennsport 08-23-2005 09:10 AM
Re: Re: Re: How could I not realize that....
LOL,..There are too many factors at work here to make wide generalizations and I was referring to Erick's RSA engine where broken rings that show up in leakdown tests do not always show a serious reduction in peak HP.
The variables are valve sealing, ring sealing, camshaft timing and wear, etc.
If you have a worn, old tired engine, you could do a few runs on a Dynojet to see what it does at the rear wheels. :)
Steve@Rennsport 08-23-2005 09:16 AM
Originally posted by Erick
Thanks guys. I'm having the fuel injectors cleaned and rebuilt. And I'll check for vacuum leaks in the intake system. Does anyone know where to get a "wand" for a propane tank to test for leaks?
Thanks for all of the valuable info.
Erick
Erick:
Its pretty easy to make one,.....:)
I took a 8" length of 1/4" ID copper tubing and drilled 6 very small holes near one end. Then, I crimped that end in a press (you coud use a vice) so gas must flow through the holes.
I used a length of surgical rubber tubing to connect the copper tube to the propane torch after I removed the burner head.
Now, you have a device that allows you to introduce propane gas into small places all over the intake system,............:)
Erick 08-24-2005 08:45 AM
Erick:
Beautiful! Great idea. Thanks.
Erick
