I used a big gear puller and no heat.
Sure they are tight but a large gear puller and a bit of strength or impact wrench and your done. See my picture, and yes the engine encountered serious failure.
Best Regards,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 08-19-2005, 09:03 PM
Super Moderator
cstreit's Avatar
Ooof!
Do tell how you an engine breaks the intermed. shaft gear off in such a hige chunk! Carnage....
Chris
2008 Yamaha R6
2001 GT3 Cup - "Pepin"
1999 Spec Miata
1996 993 RS Replica
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-19-2005, 09:49 PM
How did you get them back on after changing the aluminum gear?
Jack
Old 08-20-2005, 04:44 AM
The large gear came apart after the distributor gear decided to jump around inside my case, it produced two large holes in the case as well just below the large intermediate gear.
Pressing the new one back on was done very slowly and carefully with a wooden block and slow even taps around the entire part. Maybe not the most scientific approach but it was affective and did not harm the gear.
Best Regards,
Alex
Old 08-20-2005, 10:03 AM
ChrisBennet's Avatar
To get pretty much any gear (that has a press fit) onto a shaft I heat it up with the heat gun and it drops right on. For gears that need a little help I use a piece of PVC pipe that big enough to fit over the shaft to tap the gear(s) down on the shaft.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 08-20-2005, 11:48 AM
Jubbie's Avatar
Almost the same thing happened to me when I pulled my chain gears to replace the aluminum gear. Pullers messed the chain gears all up.
Next round was done on a press and heating up the steel gears with a torch. They let go with a exilerating PING.
Ahh the monitary impact of learning a lesson...
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 08-20-2005, 11:37 PM
John makes a good point. A bearing seperator and a press would be gentler on the chain sprockets. I usually replace the sprockets with the chain.
-Chris
'07 BMW 328i Coupe
Old 08-21-2005, 04:41 AM
