-   -   Head Stud Replacement (http://forums.pelicanparts.com/911-engine-rebuilding-forum/238044-head-stud-replacement.html)
1972_911T 08-27-2005 03:49 AM
Im going to replace the head studs on my 3.2 engine what I want to know is do I just replace the bottom deliver studs and keep the original steel top studs as they all look in good condition no rust etc? Also what do I replace my deliver studs with? New delivers or standard steel ones like on the intakes?
1972_911T 08-27-2005 04:13 AM
Is it possible to use the later 993 fully threaded DILAVAR studs and do these offer a greater reliability?
ChrisBennet 08-27-2005 05:10 AM
Just replace the bottom row/Dilivars with the steel 993. Do a search, I've posted the part # a few times.
Steel studs in aluminum case, closed course, professional driver, yada yada...
-Chris
