LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
AirBorne!
I just stumbled onto this thread after a search for 2.8SS. Thanks to all that shared their knowledge. I have a fairly rust free 1970T chassis with steel turbo fenders front and rear. I've been searching for the "right" engine for it. The quick solution is to build a 3.0, put on PMOs and trot around. But with this BAD BOY I can prance around all day long. Thanks Henry!
For all those with knowledge, if I were to build this 2.8SS using PMOs instead of MFI, would I need to change any of the intake/exhaust sizes?
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 02-05-2017, 03:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
2.8ss
Hi,in the mid 90,s I started using the early 3.6 heads on my 2.8 ss engines.I had been using 3.2 heads which worked quite well.I use Ti valves that are larger as well.Also ti-rods that are 132mm long to get a 2 to 1 rod ratio.Stud spacing needs to be narrowed a little bit on the heads.I use a 3.2 repair head gasket to seal it up tight.930 104 381 01 and there are no leaks.This motor spins to 9300 rpm and makes 248 ft.lbs. of torque with a very long flat torque curve.Outer portion of the piston is trimmed to get proper head clearance with the longer rod.Like Henry said the best motor that Porsche never built.I use 45mm slides with Motec and a hand built step exhaust to let it breath.Makes 374 H.P.at 9300.Power starts to drop off a bit a 9100.It is simply a stunning engine and revs way quicker than larger motors.Fred
Old 02-06-2017, 09:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
All I can say is .....wow!!!!
Back in the day I raced a 3.8L 993 RSR with what I was told had everything including the sink thrown at it. It made just over 400 BHP. It also ran out of gas at just over 8200 RPM. Your engine makes almost as much one whole litre of displacement smaller and still makes power almost 1000 RPM higher.
You sir, need to go looking for the holy grail. You will probably find it!!!
Old 02-06-2017, 09:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
The latest adventure into short stroke magic was the 3.1 liter engine we built for a customer in the US military stationed in Sicily.
Supertec 3.1 liter Short Stroke 9000 RPM 2 valve
1982 930 Turbo case (GT3 squirters)
Shuffle pins
Boat Tail
Supertec SuperCrank billet 66mm full cross drilled
R&R billet connecting rods (GT3 config: 53mm big end, 21mm small end & 130mm oal)
GT3 Bearings coating by Calico Coating
996 TT oil pump
Racing IWIS chains Supertec idler arms
964 steal countershaft
Supertec Head studs
LN Nickie cylinders 100mm
Supertec 906 cylinder tin
11.5:1 JE FSR pistons, 60 grams lighter than conventional pistons
Custom DC 90 cams
Early forged rockers w/dry film pads
Xtreme Cylinder heads
50mm PMO Carbs (manifolds 47 x 50mm)
Burnham Motorsport Twin plug distributor
Burnham Motorsport sump cover
Series 900 fan shroud
Supertec Power Pulley
Supertec RSR flywheel
Originally Posted by Xtreme
Port Flow Analyzer v3.0 XTREME CYLINDER HEADS
Test Comments:
Vlv Dia
1.850"
1.575"
Stem Dia.31"
Lift Range Test Flow Leak Corr Pres Pres CFM
Int #1 .100 4 28.00 34.00 .0 67.7
Int #1 .200 4 28.00 79.00 .0 157.2
Int #1 .300 5 28.00 73.50 .0 216.8
Int #1 .400 5 28.00 84.00 .0 247.8
Int #1 .500 5 28.00 89.50 .0 264.0
Exh #1 .100 4 28.00 25.00 .0 51.3
Exh #1 .200 4 28.00 53.00 .0 108.7
Exh #1 .300 4 28.00 75.00 .0 153.8
Exh #1 .400 4 28.00 87.50 .0 179.4
Exh #1 .500 4 28.00 93.00 .0 190.7
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-07-2017, 08:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
2.8 extreme heads
Wow,great motor.Heads are just gorgeous.What does a motor like that cost roughly?Did you dyno it?I built a few 3.1 ss for Imsa 911 in the 80,s & the limiting factor was enough fuel .We used the Kugelfischer Rotory pump as well.Beautiful build Henry.Fred
Old 02-07-2017, 08:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #185 (permalink)
Formerly known as Syzygy
Canada Kev's Avatar
Originally Posted by Henry Schmidt View Post
The crank can be fitted into any case from 78 to 97.
The cranks use a more modern oiling design and are considerably lighter than conventional Porsche cranks. To build a 66x102 you need a 964 or 993 case unless LN makes a Nickie that is a 102 with a 105 spigot.
I believe LN does make 102 cylinders / 105 spigot for 3.2 cases. However, wouldn't that make for rather thin walls at the base? Would that make for an inherently weak area or is it a non-issue?
Kevin
Old 02-11-2017, 03:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #186 (permalink)
AirBorne!
subscribed
Old 02-21-2017, 02:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #187 (permalink)
Member 911 Anonymous
DRACO A5OG's Avatar
Wow, I am really digging those rod holders to mate the case halves, nice. Any chance of getting a close up of those things, purty please.
Love that oil plate
Were the heads chamfered for the 100 Nickies? Nice
'85 Carrera Targa
PCA/POC
Old 02-21-2017, 03:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #188 (permalink)
Tadashi Hamaguchi
I don´t know if I asked you before Henry, but why not, 70.4 stroke with 102mm pistons on 993 case? that would make same bore/stroke ratio as the 2.8SS we can have all the benefitt of the 2.8 plus we can have twin plug for free.
I have all the parts to build it, to my twin turbo engine. Ti rods from Pankl, turbo oil pump, or GT-3 oil pump, all the good stuff;
thanks
Tadashi
Old 06-03-2017, 07:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #189 (permalink)
3 restos WIP = psycho
kenikh's Avatar
thanks
Tadashi
Rod length
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-03-2017, 07:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #190 (permalink)
kenikh's Avatar
thanks
Tadashi
Rod length.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-03-2017, 07:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #191 (permalink)
al lkosmal's Avatar
Just read thru most of this old thread......one of the best threads ever and worth revisiting again & again.
RGruppe #669
http://www.x-faktory.com/
Old 06-04-2017, 08:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #192 (permalink)
kenikh's Avatar
Agreed!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-04-2017, 09:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #193 (permalink)
safe's Avatar
Talked to an engine builder last week that went the other way. Custom designed 85mm crank, 102mm cylinders for a turbocharged 4.2 liter engine.... Not sure how he got the crank to fit in there...
Old 06-04-2017, 09:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #194 (permalink)
kenikh's Avatar
Probably used Honda bearings, to start.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-04-2017, 09:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #195 (permalink)
Constitutional Liberal
Turbo_pro's Avatar
I found this old thread and thought it was worth another look.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 02-07-2019, 08:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #196 (permalink)
jm993rs's Avatar
very nice engine !!!
Old 02-08-2019, 12:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #197 (permalink)
jm993rs's Avatar
I'm loved with this thread !!!
Please the gurus of this engines .....
I'm thinking one 2.7 engine....because i have one crankshaft from engine 2.0..... I'm thinking make the conversion to short steoke !!!
Please give me ideas and view points for mount on my conversion to 914 6 GT thinking for make rally car
Thanks in advanced
Old 02-19-2019, 07:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #198 (permalink)
Thanks in advanced
914/6GT 7200 rpm
2.5 liter twin plug. 66X90 (short stroke 2.6- 66x92 is also cool)
DC 43 camshafts
Oil Pump upgrade
Crank shaft 2.2
Supertec Head studs
Aasco valve springs and retainers
Clevite rod bearings
2.2 connecting rods ARP rods bolts
Gasket set Viton (Wrightwood Racing)
12 spark plugs ngk-bkr6-ekub 46 mm PMO or Webers
6 PMO 34 mm venturis
6 PMO main jets 130
6 PMO idle jets 55
Venti port 36mm
Machine piston dome & massage transition ridge (compression adjustment) 10.0:1
Valve job & surface heads
Machine valve covers twin plug
Case Savers and 8mm stud inserts
Replace studs & surface gasket surfaces (heads)
Rebuild, convert to ARP and balance 2.2 connecting rods
Henry Schmidt
Ph: 760-728-3062
Old 02-19-2019, 08:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #199 (permalink)
Walt Fricke's Avatar
Henry - is that an oil shedding coating on those rods? And you balanced the rods after the coating? Or was that a second balance for those which changed a bit?
While you are sharing some of your specs, what cam or cams do you suggest for a SS 2.8, twin plug, EFI, ~11:1 CR, 3.2 heads, oversized valves.
Old 02-24-2019, 12:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #200 (permalink)
