LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
camgrinder's Avatar
About this time last year there was a post with a lot of good rod/stroke info..
Camshaft Selection -- First Draft
John Dougherty
Dougherty Racing Cams
Old 09-30-2005, 10:24 AM
3 restos WIP = psycho
kenikh's Avatar
Whoa...no kidding! Killer info.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-30-2005, 10:27 AM
Originally posted by Henry Schmidt
At 8500 this gets fuel yardage not mileage.
Joking aside, this engine like all other MFI engines is very thirsty.
I don't have any real fuel consumption numbers but I would guess 8-12 depending on right foot flexibility.
Henry, Why don't you test a Motronic fuel injection system (from 3.2 carrera) on your 2.8SS to see how it performs, and measure fuel mileage? (Can Motronic handle 8500rpm?)
Old 10-01-2005, 10:24 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I like MFI, always have, always will.
I'll leave the EFI engine development to those people who like it.
Fuel milaege does not interest me much.
" the fastest way to go broke in business is to get an ever growing percentage of an ever shrinking market"
Money must not be the primary motivation.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-01-2005, 11:39 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Henry, what did you set the deck height @ on the 2.8SS ?
Thanks, Scott
Scott Kinder
kindersport @ gmail.com
Old 10-16-2005, 12:55 AM
Henry - howz about posting a link with some video and soundtrack to one of your creations!! I'm sure more than a few of us would like to meditate to that!
Nabil
'71 S track car, 2.7L & Webers forever!
Old 10-17-2005, 09:07 PM
Nabil
Meditate? It sounds to me like pornography.
Henry Schmidt
Ph: 760-728-3062
Old 10-18-2005, 08:22 AM
We all have our weakness!!
Old 10-18-2005, 08:37 AM
speedingbullitt's Avatar
Henry,
How would one differentiate between a 2.2 S crank and one from an E or T??
Thanks!
Steve Benitz
Old 10-18-2005, 08:17 PM
YTNUKLR's Avatar
2.2S and E are the same.
pic:
2.0/2.2l Counterbalanced Crank Blowout At $575 Shipped
The 2.2T crank does not have counterweights, the flanges of dark metal that hang off opposite each journal. BTW, that one is still available.
Best regards, Scott
Scott Kinder
Old 10-18-2005, 08:59 PM
jluetjen's Avatar
Wow! Cool thread. There's not much that I feel that I can add at this point.
Although I wonder if some of the difference in performance between short stroke and the long stroke 911ST motors might be due to the increase rod angularity that Henry describes above. On the other hand, one of the benefits of "longer" stroked motors that Porsche's designers have always appeared to have been sensitive to is that with a "longer" stroke motor it's possible to have a more compact combustion chamber (specifically, by this I mean that the surface area to volume ratio is smaller) which results in improved combustion, reduced emissions and reduced ignition timing for a given level of performance.
Just some unquantified thoughts.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-19-2005, 06:26 AM
Thanks, Scott
Well?
Old 10-19-2005, 01:58 PM
.040 DECK HEIGHT
AND .070 VALVE TO PISTON CLEARANCE.
THIS IS THE SAME FOR ALL OUR HIGH PERFORMANCE ENGINE.
MOST ENGINE BUILDERS HAVE A SERIES OF NUMBERS THAT THEY ARE COMFORTABLE AND IN MY CASE THESE ARE THEM? THEY? IT? MINE
Henry Schmidt
Ph: 760-728-3062
Old 10-19-2005, 02:32 PM
Henry, I understand that you've used JE pistons for this application but is Mahle P&C's 95mm available for such a application? If so, what's the part #?
Old 10-21-2005, 10:21 AM
Mahle does not make a piston specifically designed for this engine configuration.
They do make a 10.5 to 1 compression, 3.0 RSR piston that you can order in a cylinder with SC bolt spacing that will work for a 2.8 SS engine. Part # from Andial is AND 10398495
Keep in mind that a 10.5 to 1, 3.0 piston was designed for a 70.4mm crank so when you install it on a 66mm crank you will loose static compression.
I have measured a loss from .5 to .58 reduction in comp. ratio when doing this conversion.
10.5 to 1 will now be as high as 10.0 to 1 and as low as 9.9 to 1.
With this engine as with all other engines of custom configuration, if compression ratio is important to you, you must measure it.
Henry Schmidt
Ph: 760-728-3062
Old 10-21-2005, 10:38 AM
Henry Thanks for all the information!!
In your opinion is the mahle 3.0 RSR in which you listed the andial p/n for superior to the JE piston for longevity? Would you recommend the mahle over the JE? I am sure there is a big cost difference, but might there be any other reasons to use/ not use the mahle 3.0 RSR set?
Thanks again!
Steve Benitz
Old 10-21-2005, 11:45 AM
kenikh's Avatar
What about Cosworth pistons in terms of longevity when compared to Mahle? Aren't Cosworth's about the same price?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-21-2005, 11:54 AM
They do make a 10.5 to 1 compression, 3.0 RSR piston that you can order in a cylinder with SC bolt spacing that will work for a 2.8 SS engine. Part # from Andial is AND 10398495.
What its cylinder wall thickness?
Is it CE ring groove delete?
Cylinder wall thickness is stock for 95 mm SC or Carrera.
CE ring is optional. Either way.
Henry Schmidt
Ph: 760-728-3062
Old 10-21-2005, 01:19 PM
Walt Fricke's Avatar
Porsche Crest Re: IT'S DONE
[QUOTE]Originally posted by Henry Schmidt
[B] AFTER OVER A YEAR IT'S DONE
2.8 SHORT STROKE 66 MM STROKE 95 MM BORE
THIS BAD BOY SHOULD MAKE 300+ HORSE POWER AND TURN 8500 RPM
Henry - has this bad boy been on a dyno of some sort by now? Any numbers you can share?
Walt Fricke
(slowly building a similar engine with 3.2 heads and wondering particularly what cam to use, though my pistons are cut for more like 12/1 which might change things)
Old 10-21-2005, 05:25 PM
